Introduzione
This guide shows how to properly remove and clean the fan. This will help prevent your GameCube from overheating.
Ricambi
Nessuna parte specificata.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
Carefully disconnect the fan connector from the socket, as depicted in the second picture.
Altre 10 persone hanno completato questa guida.
