Salta al contenuto principale
Nintendo GameCube Controller Directional Pad Replacement
Cosa ti serve
  1. Nintendo GameCube Controller Directional Pad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Directional Pad Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Directional Pad Replacement, Z Button: passo 3, immagine 1 di 2 Nintendo GameCube Controller Directional Pad Replacement, Z Button: passo 3, immagine 2 di 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Directional Pad Replacement, Circuit Board: passo 4, immagine 1 di 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Directional Pad Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Directional Pad Replacement, Directional Pad: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the rubber backing with tweezers.
  7. Nintendo GameCube Controller Directional Pad Replacement: passo 7, immagine 1 di 1
    • Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
Conclusione
Altre 5 persone hanno completato questa guida.
Sean Michel
Membro da: 01/14/13
2.600 Reputazione
8 Guide realizzate
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
32 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 40
Tutti i Tempi: 7,380
