Introduzione
For clarification, the trackpads and the directional pad are not the same. This guide is for replacing the rubber pads below the buttons, not the buttons themselves.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
Four #00 6.45mm tri-wing screws that are located at the corners of the device.
Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
Using your fingers, gently lift and remove the trackpads covering the following:
'A' and 'B' buttons
Directional Control Button Pad
'Start' and 'Select' buttons
Altre 5 persone hanno completato questa guida.
