Introduzione
The speaker is located in the center of the Game Boy Advance SP's button panel. It is not wired to the motherboard which allows for an easy fix with no soldering.
Cosa ti serve
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
Altre 13 persone hanno completato questa guida.
