Salta al contenuto principale
Nintendo DSi XL Volume Buttons Replacement
Cosa ti serve
  1. Nintendo DSi XL Volume Buttons Replacement, Battery: passo 1, immagine 1 di 2 Nintendo DSi XL Volume Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Buttons Replacement: passo 2, immagine 1 di 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Buttons Replacement, Lower Case: passo 3, immagine 1 di 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: passo 3, immagine 2 di 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: passo 3, immagine 3 di 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Buttons Replacement: passo 4, immagine 1 di 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Buttons Replacement: passo 5, immagine 1 di 3 Nintendo DSi XL Volume Buttons Replacement: passo 5, immagine 2 di 3 Nintendo DSi XL Volume Buttons Replacement: passo 5, immagine 3 di 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Buttons Replacement: passo 6, immagine 1 di 2 Nintendo DSi XL Volume Buttons Replacement: passo 6, immagine 2 di 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Buttons Replacement: passo 7, immagine 1 di 2 Nintendo DSi XL Volume Buttons Replacement: passo 7, immagine 2 di 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Buttons Replacement, Volume Control Switch: passo 8, immagine 1 di 1
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  9. Nintendo DSi XL Volume Buttons Replacement: passo 9, immagine 1 di 3 Nintendo DSi XL Volume Buttons Replacement: passo 9, immagine 2 di 3 Nintendo DSi XL Volume Buttons Replacement: passo 9, immagine 3 di 3
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  10. Nintendo DSi XL Volume Buttons Replacement: passo 10, immagine 1 di 1
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
  11. Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: passo 11, immagine 1 di 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: passo 11, immagine 2 di 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: passo 11, immagine 3 di 3
    • While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
    • Work patiently and carefully as the silicone pad is easily torn.
    • Remove the buttons from the silicone pad.
Conclusione
Brett Hartt
Membro da: 04/12/10
126.222 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.709 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 45
Tutti i Tempi: 6,257
