Introduzione
Get a better view of whats going on in your games by replacing a scratched upper screen. This is not the touchscreen.
Cosa ti serve
Use a push pin to remove the four plastic screw covers on the front bezel.
Using the flat end of a spudger, pry the Wi-Fi antenna out of its housing from within the front bezel and move it aside.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner as described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Altre 6 persone hanno completato questa guida.
4 Commenti
Yes, you're right. Also there's a gap between steps 7 to 8 because you cannot actually detach the upper screen without disconnect the board cable from the lower screen part.
By the way, I can't quite successfuly open the upper screen part on my dsi xl because it dont seem to give any space between the two covers. Any suggestions?
@Irj7 find the top lcd replacement guide here:
