Introduzione
Customize the color of your DSi XL by replacing the upper case.
Cosa ti serve
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
With the console still upside-down, open the DSi XL slightly.
Push the lower display away from the upper case.
Remove the lower display from the DSi XL.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the Phillips screw holding the metal securing bracket in place.
Lift the metal bracket off the camera.
Lift the Wi-Fi antenna off the front display bezel.
De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
Lift both of the speakers from their seats on the front display bezel.
Remove the seven 2.5 mm silver screws securing the power board to the upper case.
Lift the power board off the upper case.
Altre 3 persone hanno completato questa guida.
