Introduzione
Replace your DSi XL's speakers so you can hear Mario yell "Mamma mia" as clear as ever.
Cosa ti serve
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Use a push pin to remove the four plastic screw covers on the front bezel.
Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
Altre 3 persone hanno completato questa guida.
3 Commenti
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
is there anyway of adding two more speaker?
rust/white powder built up on a screw and can’t unscrew it
Eco - Replica
