Salta al contenuto principale
Nintendo DSi XL Power Board Replacement
Cosa ti serve
  1. Nintendo DSi XL Power Board Replacement, Battery: passo 1, immagine 1 di 2 Nintendo DSi XL Power Board Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Power Board Replacement: passo 2, immagine 1 di 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, immagine 1 di 3 Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, immagine 2 di 3 Nintendo DSi XL Power Board Replacement, Lower Case: passo 3, immagine 3 di 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Power Board Replacement: passo 4, immagine 1 di 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Power Board Replacement: passo 5, immagine 1 di 3 Nintendo DSi XL Power Board Replacement: passo 5, immagine 2 di 3 Nintendo DSi XL Power Board Replacement: passo 5, immagine 3 di 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Power Board Replacement: passo 6, immagine 1 di 2 Nintendo DSi XL Power Board Replacement: passo 6, immagine 2 di 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Power Board Replacement: passo 7, immagine 1 di 2 Nintendo DSi XL Power Board Replacement: passo 7, immagine 2 di 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Power Board Replacement, Power Board: passo 8, immagine 1 di 2 Nintendo DSi XL Power Board Replacement, Power Board: passo 8, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  9. Nintendo DSi XL Power Board Replacement: passo 9, immagine 1 di 1
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
  10. Nintendo DSi XL Power Board Replacement: passo 10, immagine 1 di 2 Nintendo DSi XL Power Board Replacement: passo 10, immagine 2 di 2
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
Conclusione
Altre 7 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
131.199 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.623 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 54
Tutti i Tempi: 18,319
