Salta al contenuto principale
Nintendo DSi XL Lower LCD Replacement
Cosa ti serve
  1. Nintendo DSi XL Lower LCD Replacement, Battery: passo 1, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    rust/white powder built up on a screw and can’t unscrew it
    Eco - Replica
  2. Nintendo DSi XL Lower LCD Replacement: passo 2, immagine 1 di 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower LCD Replacement, Lower Case: passo 3, immagine 1 di 3 Nintendo DSi XL Lower LCD Replacement, Lower Case: passo 3, immagine 2 di 3 Nintendo DSi XL Lower LCD Replacement, Lower Case: passo 3, immagine 3 di 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower LCD Replacement: passo 4, immagine 1 di 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower LCD Replacement: passo 5, immagine 1 di 3 Nintendo DSi XL Lower LCD Replacement: passo 5, immagine 2 di 3 Nintendo DSi XL Lower LCD Replacement: passo 5, immagine 3 di 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower LCD Replacement: passo 6, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 6, immagine 2 di 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower LCD Replacement: passo 7, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 7, immagine 2 di 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Lower LCD Replacement, Wi-Fi Board: passo 8, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement, Wi-Fi Board: passo 8, immagine 2 di 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Lower LCD Replacement: passo 9, immagine 1 di 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
    Can I use any other tool than a spudger?
    Noe - Replica
  10. Nintendo DSi XL Lower LCD Replacement, Motherboard: passo 10, immagine 1 di 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
    Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
    Sjoerd Hulshof - Replica
  11. Nintendo DSi XL Lower LCD Replacement: passo 11, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 11, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Lower LCD Replacement: passo 12, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 12, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Lower LCD Replacement: passo 13, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 13, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Lower LCD Replacement: passo 14, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 14, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    -This is where you can replace the charger port. i may change this comment later from May 21-June 5
    Artemy Matveev - Replica
  15. Nintendo DSi XL Lower LCD Replacement: passo 15, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 15, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Lower LCD Replacement: passo 16, immagine 1 di 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
    Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
    Paulette Williams - Replica
  17. Nintendo DSi XL Lower LCD Replacement: passo 17, immagine 1 di 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
    the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
    Rohan Grant-Dawes - Replica
    On Step 17, I only had the 3 black Philips screws on the left to remove.
    bfmackin - Replica
  18. Nintendo DSi XL Lower LCD Replacement: passo 18, immagine 1 di 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Lower LCD Replacement: passo 19, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 19, immagine 2 di 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Lower LCD Replacement: passo 20, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 20, immagine 2 di 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
    This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
    Jerod Cook - Replica
    Completed, worked perfectly! I agree with the comment about step 20, completely unnecessary.
    ian - Replica
    Fantastic! Fixed my daughter's irreplaceable DSi XL - you should see her smiles!! Not sure about step 20 I did this before reading the comments (guess there's a message there). Thanks so much whoever wrote this - you're a legend and you've made a child very happy (and a dad too thereby).
    lb9 - Replica
    I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
    bigdrum1998 - Replica
    The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
    YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
    Deanna Cortez - Replica
    I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
    bfmackin - Replica
    DONT follow this step, i missed these comments and removed my cable, it took me almost an hour (I know, way too long, I just couldn't get the cable far enough in to the slot) before the top screen finally worked. Was afraid I destroyed the cable, but it survived luckily enough.
    SaakS - Replica
  21. Nintendo DSi XL Lower LCD Replacement, Lower Display Assembly: passo 21, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement, Lower Display Assembly: passo 21, immagine 2 di 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Nintendo DSi XL Lower LCD Replacement, Lower LCD: passo 22, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement, Lower LCD: passo 22, immagine 2 di 2
    • Insert a spudger between the touchscreen and top right corner of the display.
    • Slide the spudger down the right side of the display to free the edge of the touchscreen.
    When removing the digitizer, note, there is an adhesive around the perimeter of the mating surface of digitizer-to-lcd screen (keeps dust out also). If your new screen or digitizer does not have one (mine didn't) try to be gentle when removing the digitizer to avoid damaging the adhesive. Work above or below the adhesive strip- whatever helps keep it intact with the component you aren't replacing but if it is too stuck on one side or another you can always peel it off the other component after the fact. DON'T STRETCH IT or it won't lay nicely.
    Carlos Islas - Replica
  23. Nintendo DSi XL Lower LCD Replacement: passo 23, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 23, immagine 2 di 2
    • Continue around the bottom right corner of the display with the spudger.
    • Slide the spudger along the bottom edge of the touchscreen to separate it from the display.
  24. Nintendo DSi XL Lower LCD Replacement: passo 24, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 24, immagine 2 di 2
    • Continue around the bottom left corner of the display with a spudger.
    • Slide the spudger along the left edge of the touchscreen to remove it from the display.
  25. Nintendo DSi XL Lower LCD Replacement: passo 25, immagine 1 di 2 Nintendo DSi XL Lower LCD Replacement: passo 25, immagine 2 di 2
    • With three sides freed, remove the touchscreen from the lower display.
    The plastic frame has to be removed from the old touchscreen, too. It's an adhesive. My new touchscreen didn't have one. When reattaching, insert the frame back into the DSi case first, then carefully drop the new touchscreen down on top of it to try to get it to line up correctly.
    Also, after everything was done, I had to run the touchscreen calibration in the DSi menu to get the touchscreen to work properly.
    bfmackin - Replica
    During re-install, when reattaching the digitizer it has to be on fairly precise otherwise the digitizer-LCD screen assembly will not fit into the "pocket" easily (won't sit all the way flush) therefore it is advisable to loosely attach the two pieces with the adhesive barely touching (to allow the pieces to slide slightly into the correct spot) or to instead install the digitizer by itself into the "pocket" then the LCD screen after (with the adhesive strip already attached to the LCD screen beforehand. Either way be careful not to get anything caught in this gap (hair, lint, fingerprints, etc) otherwise it may be annoyingly visible.
Conclusione
Altre 15 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.529 Reputazione
127 Guide realizzate
3 Commenti
DSI XL Lower LCD ZIF Socket replacement - Please help!!
Hi All, I have a DSi XL which i am trying to rescue from someone who has done a bad job of attempting a repair! It has been taken apart, although the guy didn't know how ZIF sockets work and has broken two of them. The 37 pin Lower LCD ZIF socket, and the 15 pin power board ZIF socket. I am experienced electronic engineer and and hand soldered SMD components before so i think i can replace these and get this DSi working again. My only problem is, i cannot find any reference to exactly what these sockets are or where to buy some! Can anyone offer any information about these sockets at all? I really want to get hold of some and get this back in action. Any help locatin the correct parts would be very very welcomed.
Many thanks in advance all
Matt Stroud
mattstroud - Replica
Great set of instructions - Thanks
Replaced the lower screen for the first time with no problems
Thanks
Roy Bastiman - Replica
Hello and thanks for sharing.
I have two units of this model.
The first one sunk in water and I’m not sure it can be fixed (can it?)
The other one’s lower screen got a slight crack when it was hit by the kids using it with the device pen, and the touch response has been limited since. I was wondering if I can take out only the touch layer of the sunken device’s screen and install it on the new one.
Thanks.
Shimmy Weitzhandler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 116
Tutti i Tempi: 17,139
