Salta al contenuto principale
Nintendo DSi Motherboard Replacement
Cosa ti serve
  1. Nintendo DSi Motherboard Replacement, Battery Cover Removal: passo 1, immagine 1 di 2 Nintendo DSi Motherboard Replacement, Battery Cover Removal: passo 1, immagine 2 di 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Motherboard Replacement, Taking out the Battery: passo 2, immagine 1 di 2 Nintendo DSi Motherboard Replacement, Taking out the Battery: passo 2, immagine 2 di 2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
    This is also where the water damage indicator is located, if that's important
    Vaulto - Replica
  3. Nintendo DSi Motherboard Replacement, Lower Case Assembly: passo 3, immagine 1 di 2 Nintendo DSi Motherboard Replacement, Lower Case Assembly: passo 3, immagine 2 di 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
    One of the feet did break on me, tweezers came in handy for picking it out
    Willie Narvaez - Replica
    I unfolded and sharpened a paperclip. You can use that to stab and hook the rubber without tearing it, as the rubber is thick enough to reseal when reinserted.
    Keegan Andersen -
    Nasty, broke my spudger and the feet in this step.
    TimedIn - Replica
  4. Nintendo DSi Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
    Impossible d'enlever les vises… trop serré! comment faire?
    evrobert03 - Replica
    i can't get the screw by the gamecard slot out, PH#00 is too small and PH#0 is too big
    Iblowup - Replica
    same problem here. maybe try a JIS?
    darth mango -
  5. Nintendo DSi Motherboard Replacement: passo 5, immagine 1 di 3 Nintendo DSi Motherboard Replacement: passo 5, immagine 2 di 3 Nintendo DSi Motherboard Replacement: passo 5, immagine 3 di 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Motherboard Replacement: passo 6, immagine 1 di 2 Nintendo DSi Motherboard Replacement: passo 6, immagine 2 di 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Motherboard Replacement, Wi-Fi Board: passo 7, immagine 1 di 1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Motherboard Replacement: passo 8, immagine 1 di 1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    After reassembling it, I switched my Nintendo DSi xl On and only the blue power light, is on after that it doesn't respond any more, except while charging it blinks
    Phillips - Replica
  9. Nintendo DSi Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
    do not pry up! pull to one side so you don't disconnect the clip from the motherboard!
    Lisa - Replica
    Actually Lisa, you are incorrect. If you pull to one side you WILL end up pulling the connector off the motherboard. It is designed so that you ARE MEANT TO pry it upwards out of the connector. All you need to do is use the point or corner of the flat edge of a spudger (or a small flat-headed screwdriver), push it ever so slightly under the middle of the small white plug where there is a small recess in the connector for just this purpose. Prying the plug up in this fashion you should clear the connector with the spudger by prying it up through the recess rather than catching the connector and pulling it off the board.
    James Gravestock -
    how to fix if the clip comes off of the motherboard?? please help!
    jaime - Replica
    Push it back in straight if it is still in one piece.
    Tman Tech -
    If the socket comes off the motherboard along with the connector, what’s the best way to fix it?
    Kimberly Meyer - Replica
    it has to be soldered back on, so if you can't do it yourself, find someone who can (maybe a local repair shop).
    just some mango -
    I already pull it off from board new i have to learn how to weld it back
    Mussa Ding - Replica
  10. Nintendo DSi Motherboard Replacement: passo 10, immagine 1 di 2 Nintendo DSi Motherboard Replacement: passo 10, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
    I accidentally broke the retaining flap off of the lower touchscreen’s socket. Is it possible to reattach it?
    Thewolfpack23x - Replica
    Mine broke off too. At first I thought it would just pop back in, but when I looked at it under magnification, I can see that a tiny piece of plastic actually snapped off the flap. I think we're farked. Looks like the only way to fix would be to solder on a new cable connector.
    trevorsklar -
    i love and hate flex cables.
    they are flat and awesome, but every single flap for the connectors has broken for me (past experience vent lmao)
    Vaulto - Replica
  11. Nintendo DSi Motherboard Replacement: passo 11, immagine 1 di 2 Nintendo DSi Motherboard Replacement: passo 11, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
    When I was putting mine back together, the flap popped off and when I tried to put it on with a tweezers, it snapped. Any suggestions other than scrap it or use it without the touchscreen? Pictures at https://sites.google.com/site/memesbyluc...
    Lucas Hoekstra (Lucas9810) - Replica
    This little flap is a pain in the butt to get back in! If there is any way to bypass the removal of this, my advise is to do it!
    Tamara Girodie - Replica
    Adding on: The cable actually ended up breaking as the tweezers I used to put it back in scraped part of the gold ribbon off. Be extremely careful!!!
  12. Nintendo DSi Motherboard Replacement: passo 12, immagine 1 di 2 Nintendo DSi Motherboard Replacement: passo 12, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
    This one's super annoying to get back in
    FarmYard Gaming - Replica
  13. Nintendo DSi Motherboard Replacement: passo 13, immagine 1 di 1
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Motherboard Replacement: passo 15, immagine 1 di 3 Nintendo DSi Motherboard Replacement: passo 15, immagine 2 di 3 Nintendo DSi Motherboard Replacement: passo 15, immagine 3 di 3
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
    I actually chose to leave this ribbon cable connected, and had no issues completing the rest of the steps around this. Just be careful not to pull the cable!
Conclusione
Altre 20 persone hanno completato questa guida.
4 Commenti
do you know r78's value?
beyazit cengiz - Replica
used this guide to swap the stock power connector to a usb micro one, was a bit tricky because the sockets I use have some holes on their sides where solder kept flowing in, but in the end it works and it’s totally worth it. did the same to my old ds lite too, works flawlessly.
SomeFishySnail - Replica
Is the motherboard paired? I'm replacing a shotty chairing repair. (One of the pads on the charger port is ripped off and not soldered well) wouldn't it be easier just to swap the whole board and nothing else?
Daniel Mitchell - Replica
I followed the instructions but my Nintendo DSi won't boot up
Lê Hoài Nam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 217
Tutti i Tempi: 40,984
