Salta al contenuto principale
Nintendo DSi Dual Camera Assembly Replacement
Cosa ti serve
  1. Nintendo DSi Dual Camera Assembly Replacement, Battery: passo 1, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift out of the lower case.
  2. Nintendo DSi Dual Camera Assembly Replacement: passo 2, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 2, immagine 2 di 2
    • Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Dual Camera Assembly Replacement, Lower Case Assembly: passo 3, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement, Lower Case Assembly: passo 3, immagine 2 di 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
  4. Nintendo DSi Dual Camera Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Dual Camera Assembly Replacement: passo 5, immagine 1 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 5, immagine 2 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 5, immagine 3 di 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Dual Camera Assembly Replacement: passo 6, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 6, immagine 2 di 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Dual Camera Assembly Replacement, Wi-Fi Board: passo 7, immagine 1 di 1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Dual Camera Assembly Replacement: passo 8, immagine 1 di 1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DSi Dual Camera Assembly Replacement, Motherboard: passo 9, immagine 1 di 1
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  10. Nintendo DSi Dual Camera Assembly Replacement: passo 10, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 10, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
  11. Nintendo DSi Dual Camera Assembly Replacement: passo 11, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 11, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  12. Nintendo DSi Dual Camera Assembly Replacement: passo 12, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 12, immagine 2 di 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
  13. Nintendo DSi Dual Camera Assembly Replacement: passo 13, immagine 1 di 1
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Dual Camera Assembly Replacement: passo 14, immagine 1 di 1
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Dual Camera Assembly Replacement: passo 15, immagine 1 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 15, immagine 2 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 15, immagine 3 di 3
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
  16. Nintendo DSi Dual Camera Assembly Replacement, Lower LCD Assembly: passo 16, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement, Lower LCD Assembly: passo 16, immagine 2 di 2
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
  17. Nintendo DSi Dual Camera Assembly Replacement, Dual Camera Assembly: passo 17, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement, Dual Camera Assembly: passo 17, immagine 2 di 2
    • Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel.
  18. Nintendo DSi Dual Camera Assembly Replacement: passo 18, immagine 1 di 1
    • Remove the four Phillips screws securing the rear bezel to the front bezel.
  19. Nintendo DSi Dual Camera Assembly Replacement: passo 19, immagine 1 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 19, immagine 2 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 19, immagine 3 di 3
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
    • Lift the rear bezel straight up out of the DSi.
  20. Nintendo DSi Dual Camera Assembly Replacement: passo 20, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 20, immagine 2 di 2
    • De-route the microphone and Wi-Fi antenna cables through the opening located on the bottom DSi's framework.
  21. Nintendo DSi Dual Camera Assembly Replacement: passo 21, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 21, immagine 2 di 2
    • Remove the five Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board from the DSi.
  22. Nintendo DSi Dual Camera Assembly Replacement: passo 22, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 22, immagine 2 di 2
    • Push the metal hinge pin inward on the D-pad side of the front lower panel with the tip of a spudger.
    • The pin should move about 3 mm and stop. It is not necessary to try to completely remove the pin.
  23. Nintendo DSi Dual Camera Assembly Replacement: passo 23, immagine 1 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 23, immagine 2 di 3 Nintendo DSi Dual Camera Assembly Replacement: passo 23, immagine 3 di 3
    • Slightly detach the lower and upper halves of the DSi.
    • Do not completely separate both halves yet. There are several ribbon cables that remain threaded through both panels.
    • De-route the upper LCD and dual camera ribbon cables through the slit near the ABXY side of the front lower panel.
    • Separate the lower and upper halves from each other.
  24. Nintendo DSi Dual Camera Assembly Replacement: passo 24, immagine 1 di 1
    • Using your fingers, grasp the microphone cable and remove it from the front bezel assembly.
    • The microphone will likely pop out of its housing, so it is probably easier to completely remove it at this point.
    • De-route the Wi-Fi antenna cable through the hinge.
  25. Nintendo DSi Dual Camera Assembly Replacement: passo 25, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 25, immagine 2 di 2
    • Tightly coil the display and dual camera ribbon cables enough to push them through the steel hinge tube.
    • Remove the steel hinge tube.
    • Carefully push both coiled ribbon cables through the tube molded into the front upper panel.
  26. Nintendo DSi Dual Camera Assembly Replacement: passo 26, immagine 1 di 1
    • Pry the front-facing camera straight up out of its housing in the front bezel.
  27. Nintendo DSi Dual Camera Assembly Replacement: passo 27, immagine 1 di 2 Nintendo DSi Dual Camera Assembly Replacement: passo 27, immagine 2 di 2
    • Lift the rear-facing out of its housing in the front bezel.
    • Remove the dual camera cable assembly from the DSi.
Conclusione
Altre 4 persone hanno completato questa guida.
3 Commenti
what happened if the pin goes in to far? (step 22)
jaime - Replica
I have a weird question: If I remove the cameras, and reassemble the device without them, will it still work?
Will Stein - Replica
It most likely will. My DSi is missing its camera assembly and works fine. Minus the features of the camera.
Elijah -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 67
Tutti i Tempi: 8,237
