Salta al contenuto principale
Nintendo DS Lite Shoulder Buttons Replacement
Cosa ti serve
  1. Nintendo DS Lite Shoulder Buttons Replacement, Remove the battery cover: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Replacement, Remove the lower case: passo 2, immagine 1 di 1
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Replacement: passo 3, immagine 1 di 1
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Replacement: passo 4, immagine 1 di 3 Nintendo DS Lite Shoulder Buttons Replacement: passo 4, immagine 2 di 3 Nintendo DS Lite Shoulder Buttons Replacement: passo 4, immagine 3 di 3
    • You can now access the micro-button component and replace or repair anything as needed.
Conclusione
To reassemble your device, follow the steps in reverse order after making your repair.
Altre 5 persone hanno completato questa guida.
3 Commenti
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - Replica
たしかにそうですね!!!
kawagoe -
とても、わかりやすくて、しっかり修理できました!
kawagoe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 242
Tutti i Tempi: 6,558
