Introduzione
Replace the rear display bezel to give you DS Lite a face lift!
Cosa ti serve
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
Remove the motherboard from the DS Lite.
Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
Remove the two 8.3 mm Phillips screws securing the upper case to the display assembly.
Use a push pin to remove the four plastic screw covers on the front bezel.
Altre 18 persone hanno completato questa guida.
3 Commenti
Are there any front bezel parts yall recommend? Had someone break my hinge and am looking to replace it.
Did you ever get a solution for the hinges? I just had the same thing happen😞
Did you ever get a solution for the hinges? I had the same thing happen 😞
