Introduzione
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
Ricambi
Nessuna parte specificata.
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
Peel off the back foam on the bottom touch screen to expose the ribbon cable.
Gently lift the screen out of the base.
Altre 19 persone hanno completato questa guida.
Un commento
I like it but add a step 12 maybe, to see how to put in a new screen.
