Salta al contenuto principale
Nintendo 64 Rumble Pak Battery Replacement
Cosa ti serve
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: passo 1, immagine 1 di 1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: passo 3, immagine 1 di 1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: passo 4, immagine 1 di 3 Nintendo 64  Rumble Pak Battery Replacement: passo 4, immagine 2 di 3 Nintendo 64  Rumble Pak Battery Replacement: passo 4, immagine 3 di 3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Conclusione
Carly Bowen
Membro da: 07/20/15
312 Reputazione
1 Guida realizzata
Texas Tech, Team 3-6, Rauch SU 2015 Membro di Texas Tech, Team 3-6, Rauch SU 2015
TTU-RAUCH-SU15S3G6
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 53
Tutti i Tempi: 4,739
