Introduzione
This guide to replace the Power Button will take you through the steps of disassembling the Nintendo 3DS past the motherboard in order to access the Power Button.
Parti
Nessuna parte specificata.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set aside.
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
Position the device such that the game cartridge slot is located at the top.
Locate the IR board located on the upper right side of the motherboard.
Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
Using a plastic opening tool, pry off the Wi-Fi board.
The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
Using tweezers remove the rubber cap located on the bottom left hand corner.
Use the tweezers to pull out the power button.
Altre 2 persone hanno completato questa guida.
Un commento
Does anyone have any idea where I can get a spare power button (black plastic part) and the rubber bit?
I've found the rubber bit on ebay but for the life of me I cannot find the plastic part (In the UK at least)
Thanks.
