Introduzione
Voice recognition not working? Screaming at your Nintendo 3DS XL in hopes the game will finally pick up your voice? This guide will take you through the steps necessary to install a new microphone to have you back playing your favorite games in no time.
Cosa ti serve
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set it aside.
Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
Insert the plastic opening tool into the opening located on the right side of the battery.
Pry off the battery from the lower casing.
Lift the battery out of the case and set aside.
My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
Altre 4 persone hanno completato questa guida.
2 Commenti
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
please learn to repair the mic of new 3ds xl
Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
justjustintuber - Replica
what type screwdriver do i use?!? its so small!!!!
Matthew - Replica
I had success using a #00 Phillips head
Jake S -
Can't clip the front of the back cover back in
Macro Man - Replica
I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
Issu -
I found these were actually #00
Demosthien - Replica
The screws in the 1st picture are stripped. What screwdriver head do I use?
Adric101 - Replica
