Salta al contenuto principale
Nintendo 3DS XL Left Bumper Replacement
Cosa ti serve
  1. Nintendo 3DS XL Left Bumper Replacement, Left Bumper: passo 1, immagine 1 di 1
    • Remove the SD card and the game cartridge from the device.
  2. Nintendo 3DS XL Left Bumper Replacement, Battery removal: passo 2, immagine 1 di 2 Nintendo 3DS XL Left Bumper Replacement, Battery removal: passo 2, immagine 2 di 2
    • Locate the battery cover panel on the back of the device.
    • Unscrew the two screws on the battery cover panel with a Phillips #00 screwdriver.
    • Remove the battery and battery cover panel.
  3. Nintendo 3DS XL Left Bumper Replacement: passo 3, immagine 1 di 1
    • Remove the four screws on the battery panel using the Phillips #00 screwdriver.
  4. Nintendo 3DS XL Left Bumper Replacement: passo 4, immagine 1 di 1
    • Locate the two screw covers on the bottom of the back panel, near the middle of the device.
    • These sticker-like covers are small, round, and made of rubber or plastic.
    • Insert the tip of a flathead screwdriver or spudger and gently pry the cover off by applying upward pressure.
    • You may need to wiggle the tool back and forth a bit to loosen the two covers.
    • Remove the two screws located behind the screw covers using a Phillips #00 screwdriver.
  5. Nintendo 3DS XL Left Bumper Replacement: passo 5, immagine 1 di 2 Nintendo 3DS XL Left Bumper Replacement: passo 5, immagine 2 di 2
    • Remove the screw near the game card compartment using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Left Bumper Replacement: passo 6, immagine 1 di 2 Nintendo 3DS XL Left Bumper Replacement: passo 6, immagine 2 di 2
    • Lift the back panel off of the device.
    • Be cautious not to pull any ribbons or cables from the motherboard as you remove the back panel.
    • Locate and disconnect the ribbon cables from the motherboard by gently pulling on the tabs that hold them in place.
  7. Nintendo 3DS XL Left Bumper Replacement: passo 7, immagine 1 di 2 Nintendo 3DS XL Left Bumper Replacement: passo 7, immagine 2 di 2
    • Remove the three left bumper assembly screws using Phillips #00 screwdriver.
    • Once the three screws are removed, gently remove the left bumper assembly from the device.
    • The spring may eject from the assembly as you remove it.
    • Remove the hinge pin from the bumper assembly.
  8. Nintendo 3DS XL Left Bumper Replacement: passo 8, immagine 1 di 1
    • Separate the bumper from the bumper assembly
  9. Nintendo 3DS XL Left Bumper Replacement: passo 9, immagine 1 di 2 Nintendo 3DS XL Left Bumper Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Using a spudger or a flathead screwdriver, gently pull the ribbon cable straight out of the connector in order to remove it.
    • The ribbon cable can be removed by other means such as using gloves or a microfiber cloth if preferred.
    • Replace the left bumper ribbon cable.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
No steps on how to install the new bumper?
Alex Tomalty - Replica
good but i wish there were reinstall instructions
Rowan Webb - Replica
I think that it's just basically do the steps backwards then you have it fixed.
Ender - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 196
Tutti i Tempi: 4,845
