Introduzione
Remove the upper display front panel to replace it or to access the components inside the upper display assembly.
If you are just replacing the upper display panel, you can just heat it up, pry it off, and install the new one. There is no need to take apart everything at the bottom to replace the glass.
Cosa ti serve
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
Pull the microphone straight up out of the upper case.
Before continuing with disassembly, use a pair of tweezers to remove the clear plastic diffuser for the wireless notification LED. The small piece is likely to fall out on its own, and may be difficult to find if it lands on the floor.
Altre 13 persone hanno completato questa guida.
3 Commenti
Why remove the entire motherboard just for the upper screen? That seems completely unnecessary; just be careful with the heat gun.
Tehy remove the whole motherboard because if you pay attention ribbon cables attaching things from the top to the bottom, like the ribbon cable for the lcd that you cant remove from its socket without removing the other parts. They even have pictures on these guides… just focus a little more on paying attention and you will be alright
Just to replace the front panel you don’t need to remove anything else, its just held down with adhesive, only reason to take apart is to replace the lcd itself which isn’t what this is about.
