Introduzione
Replace the stylus housing in your Nintendo 3DS and give your metal stylus a comfortable place to sleep.
Parti
Nessuna parte richiesta.
  1. Unscrew the four Phillips #00 screws along the top of the back cover.
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Hold the device in one hand and turn it over. Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Insert a plastic opening tool into the notch in the lower case above the battery. Pry the battery up with the plastic opening tool. Grab the top edge of the battery and lift it out of the lower case.
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the nine 6.3 mm black Phillips screws from the lower case.
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  6. Lift the bottom edge of the lower case off the rest of the 3DS. There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off. Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  7. Remove the stylus from the lower case.
    • Remove the stylus from the lower case.
  8. Remove the four 2.4 mm Phillips screws that secure the stylus housing to the lower case. Use a plastic opening tool to pry the stylus housing up from the lower case. Grab the stylus housing and remove it from the lower case.
    • Remove the four 2.4 mm Phillips screws that secure the stylus housing to the lower case.
    • Use a plastic opening tool to pry the stylus housing up from the lower case.
    • Grab the stylus housing and remove it from the lower case.
Conclusione
David Hodson
Membro da: 13/04/2010
134.267 Reputazione
127 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,140
