Salta al contenuto principale
Nintendo 3DS Motherboard Replacement
Cosa ti serve
  1. Nintendo 3DS Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - Replica
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - Replica
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - Replica
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - Replica
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - Replica
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - Replica
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - Replica
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - Replica
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - Replica
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - Replica
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - Replica
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - Replica
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - Replica
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
  2. Nintendo 3DS Motherboard Replacement: passo 2, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 2, immagine 2 di 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - Replica
  3. Nintendo 3DS Motherboard Replacement, Battery: passo 3, immagine 1 di 3 Nintendo 3DS Motherboard Replacement, Battery: passo 3, immagine 2 di 3 Nintendo 3DS Motherboard Replacement, Battery: passo 3, immagine 3 di 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Motherboard Replacement, Lower Case: passo 4, immagine 1 di 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - Replica
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - Replica
    Ruined my screws because of incorrect head, thanks!
    3dsuser - Replica
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - Replica
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - Replica
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - Replica
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - Replica
    If anyone can point me to a link to purchase the 9 screws, let me know. Contacted Nintendo and they said I'd have to send it in. Email me at xavierfflores@gmail.com
    Xavier Flores - Replica
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - Replica
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - Replica
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - Replica
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - Replica
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - Replica
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - Replica
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - Replica
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - Replica
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - Replica
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - Replica
    Oh god, someone help i can’t get them out.
    Mark LaPierre - Replica
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - Replica
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - Replica
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - Replica
  5. Nintendo 3DS Motherboard Replacement: passo 5, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 5, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 5, immagine 3 di 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - Replica
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - Replica
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - Replica
  6. Nintendo 3DS Motherboard Replacement, Circle Pad Joystick: passo 6, immagine 1 di 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
    my screws wont stop spining what to i do? i have the same problem with other screws and this leavs my joystick very loss and it is dificult to muve it becuase it is aganst the case not lifted up? any sugestions? (sorry for my bad speling jaja im very bad at speling..)
    AppleTopic - Replica
    I think you stripped your screws. I think the best solution is to change the upper cover of the lower assembly and the screws. The fastest, but temporarily is to stick in some way the joystick housing to the cover, but it won’t last long, so do this only if you have to use your console while you wait the cover to come. Anyway, so not overtighten the new screws, or you will be in the same situation once again.
    Daniele Carminati -
  7. Nintendo 3DS Motherboard Replacement: passo 7, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 7, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 7, immagine 3 di 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
    When reassembling verify that the circle pad control is oriented right. I had to go back in after completion when I realized it wasn't centered.
    Daniel Johnson - Replica
    I would not disable the back side all the way because it could really mess up your 3DS.
    masterspeggy3 - Replica
    From this step, follow this video https://youtu.be/XGdRim2Mvrk?t=627
    you can skipp from step 8 to 20
    lots of unnecessary steps
    Bruno N - Replica
  8. Nintendo 3DS Motherboard Replacement: passo 8, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 8, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 8, immagine 3 di 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
    Can you replace a zif socket? The little metal pieces on mine broke off...
    Colton Alverson - Replica
    YOUR &&^&@@ HAHAHAAHA, no you cant you would have to purchase a new motherboard i feek you bro happened in my first time
    vrobinson -
    you might want to find someone who is skilled in component level microsoldering for that
    Samuel Martin -
    The retaining flap on mine broke off, is there any way to fix it?
    Madi Hansen - Replica
    Don't do this step! it is not necessary. you can skip steps 8 through 20
    S Maduras - Replica
    Skip steps 8 through 20. It will save a lot of time. Thanks S Maduras for the warning.
    clarissa.vetintegral - Replica
    Thanks S Maduras! Your tip
    made this super easy. No need for steps 8-20.
    Carl Vero -
    OH MY GOD THANK YOU SO MUCH!!!! I'm sure I would have destroyed my ds if I did all that
    Amber Selley -
    Just like everyone else I recommend skipping to step 21. You don't need to take all the components out to replace the circle pad.
    Callum M. - Replica
    Skip steps 8-20 like they said!! Doing all those unnecessary steps wasted so so much time and frustrated me hugely by causing me to damage my microphone ribbon cable…
    Falcon - Replica
    What do you mean by skipping 8-20? Do I not need to remove the screws in order to replace the lower LCD?
    Marion Saga -
  9. Nintendo 3DS Motherboard Replacement: passo 9, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 9, immagine 2 di 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
    When reassembling, you can use the pointy end of the spudger to align the hold again with the joystick. It’ll probably have bounced around while you’re moving other things.
    anthonyhersey - Replica
  10. Nintendo 3DS Motherboard Replacement, SD Board: passo 10, immagine 1 di 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. Nintendo 3DS Motherboard Replacement: passo 11, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. Nintendo 3DS Motherboard Replacement: passo 12, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 12, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 12, immagine 3 di 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - Replica
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
  13. Nintendo 3DS Motherboard Replacement, Wi-Fi Board: passo 13, immagine 1 di 2 Nintendo 3DS Motherboard Replacement, Wi-Fi Board: passo 13, immagine 2 di 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. Nintendo 3DS Motherboard Replacement: passo 14, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 14, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 14, immagine 3 di 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
    That moment you bought all your supplies and realise while removing the wifi chip the antenna is not plugged in because you forgot to plug it in last time……… Scew me…
    Sidney the wolf - Replica
  15. Nintendo 3DS Motherboard Replacement, Motherboard Assembly: passo 15, immagine 1 di 2 Nintendo 3DS Motherboard Replacement, Motherboard Assembly: passo 15, immagine 2 di 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. Nintendo 3DS Motherboard Replacement: passo 16, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 16, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 16, immagine 3 di 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
    Can there be a guide on how to replace this part? I pry on the socket accidentally.
    im just a Ordinary marker - Replica
    I don't even know where they sell a new socket for this, but you'd need to have a soldering station and know how to micro solder. assuming no pads where ripped off then you'd just solder it back down. if a pad broke then you'd need to run jumpers to fix it. in short its very difficult and expensive to fix unless you have the know how and the tools already.
    ssanchez7610 -
  17. Nintendo 3DS Motherboard Replacement: passo 17, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 17, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
    Be sure to fit the motherboard inbetween the joystick and volume slider in properly (you can double check by seeing if the volume slider on the outside goes up and down smoothly). When I closed it the first time it was stuck on full volume so I needed to go back in and readjust!
    Veronika Todd - Replica
    When putting the cable back I recommend to open the 3ds while keeping it face down so the cable has more room to fit.
    Roberto Cantu - Replica
    Thank you so much, opening the 3ds is needed to fit the cable back easily.
    Halefall -
    The camera ribbon cable contacts face towards the motherboard, the speaker ones face away.
    David Madrigal - Replica
  18. Nintendo 3DS Motherboard Replacement: passo 18, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 18, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 18, immagine 3 di 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
    Do yourself a favor and DON'T remove the 2.5 mm silver screw (yellow circle). It just holds in a little plastic bit under the volume control. The board comes out just fine with the screw still in. If you remove it, the plastic bit will fall out at random when you turn over the case.
    First time I took mine apart, I noticed something fall out later, tracked it down and then puzzled over what it was and where it came from.
    Chupi - Replica
    There is some adhesive where the AC adapter plugs in so I recommend watching out for that
    Devin Stephenson - Replica
  19. Nintendo 3DS Motherboard Replacement: passo 19, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 19, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 19, immagine 3 di 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
    Reinserting this ribbon cable is quite difficult. I found opening the case so that it sits upright at a 90 degree angle helps. The first two times I tried reassembling the top display did not work. Turned out that I was not inserting the ribbon cable in enough. I used tweezers to push this in by gently grabbing the ribbon cable. I was continually inspecting the cable for damage but apparently did not damage it. If anyone has a better idea on how to reinsert this cable I think others would greatly appreciate it.
    pbrazis - Replica
    Putting the cable back in is the hardest part out of all of this (if you can get past the screws near the beginning). If you have a friend that you trust very much and is very gentle, another pair of hands here really will help. If you're without a friend, make sure to use some flat, angled precision tweezers to push the ribbon in with one hand (pointed tweezers will do in a pinch but you'll have to be careful - I put a small dent in the ribbon and thought I'd broke it), and then use a spudge or something in the other to push the flap down.
    Also worth noting is that the ribbon for the top screen also handles the 3D - if you complete the guide and find you are unable to turn the 3D effect off, you didn't insert the ribbon enough, as I had the problem and re-inserting the ribbon fully fixed it.
    malcolmdemaggio - Replica
    Careful when reassembling -- watch the position of the black wifi antenna wire! I got mine most of the way back together and noticed it wouldn't close all the way. This wire had come out of the little posts holding it in place and was wedged between the screen and motherboard. Now I have to take it all apart again to fix this.
    Also if you're taking the board out of a working unit to get at the CLK signal to backup the NAND chip ("hardmod"), you don't need to remove the difficult ribbon cable in this step, or the other two wide ones at the top right from earlier. Leave them attached and swing the board out. It won't rotate a full 180 degrees to sit flat outside the unit, but you can open the screen 90 degrees to prop the rest up while having the board out on your table.
    Chupi - Replica
    I recommend not taking it off in the first place, as reattaching it is awfully difficult. You can easily clean out your abxy buttons with it still attached
    Martin - Replica
    I am having problems re-inserting the three ribbon cables (3DS XL). Do you need to flip up the retaining flaps first? (I just pulled them out of the slots when removing them.
    darren.brundell - Replica
    if the flap for the ribbon cable breaks what do you do
    lionmine ____ - Replica
    who else felt really proud after finally reinserting the cable
    Harrison Rigg - Replica
    The easiest way to get that ribbon back in is to hold it with some reverse tweezers that I fix it sells and use it to grab the ribbon and hold it while you fiddle with getting the ribbon in the slot. It’s super easy this way. You’ll have it installed in 36 seconds. Try it. (Reverse tweezers…press to release ones)
    Chris - Replica
  20. Nintendo 3DS Motherboard Replacement: passo 20, immagine 1 di 1
    • Remove the motherboard assembly from the rest of the device.
    Make sure when putting the motherboard back onto the bottom part of the casing that the antenna wire is where it should be - the first time I put this back together the wire got loose and was smooshed in between the casing and the Y and Power buttons, causing them to be stiff/not work. Using the spudge should help in pushing the wire back into the slots along the inside of the case.
  21. Nintendo 3DS Motherboard Replacement, Lower Display Assembly: passo 21, immagine 1 di 3 Nintendo 3DS Motherboard Replacement, Lower Display Assembly: passo 21, immagine 2 di 3 Nintendo 3DS Motherboard Replacement, Lower Display Assembly: passo 21, immagine 3 di 3
    • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
    • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
  22. Nintendo 3DS Motherboard Replacement: passo 22, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 22, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the touchscreen ribbon cable ZIF socket.
  23. Nintendo 3DS Motherboard Replacement: passo 23, immagine 1 di 3 Nintendo 3DS Motherboard Replacement: passo 23, immagine 2 di 3 Nintendo 3DS Motherboard Replacement: passo 23, immagine 3 di 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
    • Pull the ribbon cable out of the connector with a pair of tweezers.
    • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
  24. Nintendo 3DS Motherboard Replacement: passo 24, immagine 1 di 2 Nintendo 3DS Motherboard Replacement: passo 24, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD data ribbon cable ZIF socket.
  25. Nintendo 3DS Motherboard Replacement: passo 25, immagine 1 di 1
    • Grasp the lower display assembly and pull it directly away from the motherboard.
  26. Nintendo 3DS Motherboard Replacement, Microphone: passo 26, immagine 1 di 2 Nintendo 3DS Motherboard Replacement, Microphone: passo 26, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
  27. Nintendo 3DS Motherboard Replacement: passo 27, immagine 1 di 1
    • Lift the microphone and its attached ribbon cable off the motherboard.
  28. Nintendo 3DS Motherboard Replacement, Volume Switch: passo 28, immagine 1 di 2 Nintendo 3DS Motherboard Replacement, Volume Switch: passo 28, immagine 2 di 2
    • Turn the motherboard over.
    • Use the flat end of a spudger to pry the volume switch connector out of its socket on the motherboard.
  29. Nintendo 3DS Motherboard Replacement: passo 29, immagine 1 di 1
    • Remove the volume switch from the motherboard.
  30. Nintendo 3DS Motherboard Replacement, Motherboard: passo 30, immagine 1 di 1
    • The motherboard remains.
    Anyone know the positive side on the power plugin on Nintendo 3ds
    Terence Antoine - Replica
    did all about 6 times...my top lcd is black
    sound works&3d slider lights up
    what did i do wrong?
    softedgedknife - Replica
Conclusione
Altre 35 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
149.211 Reputazione
127 Guide realizzate
11 Commenti
This guide seriously helped me get a broken 3DS and replace the motherboard to make it a working one. Thank you for doing this guide, you are awesome. :)
Mr Blubird - Replica
I can't thank you enough for this guide! My 3 year old submerged my 8yr olds coveted 3DS in the toilet yesterday...I frantically took it apart as soon as I found it (knew not to turn it on) and wisely took pics on my phone as I frantically took apart each piece to get it dried....was however up all night dreading my ability to put it back together again...until I found this awesome step by step guide. Won't try to put it back together for another few days, but I will update my post and let you know if I got it working again:) Thanks so much!
abdefreitas - Replica
I need help!
My 3DS is acting alone directional up!
I opened the device and realized that there is a short between TP85 and ground !
I need to know what CI is responsible for the control functions !
Thanks!
Rilson da Silva Ferraz - Replica
The control functions are on the back of the motherboard facing the lower screen. It is the 4 white buttons right below the huge gap where the circular pad goes
afdflol82 -
Excellent guide. This is an incredibly frustrating device to take apart and get back together.
Probably the toughest part is the ribbon cables. They're positively tiny and some of them force you to insert them without much space to work. The best strategy I've found is to use a small poking tool like a pen cap clip to nudge them very patiently into place. First one corner in the socket so it doesn't fly back out, then nudge it along and get the other corner. Then straighten it out to line up perfectly. Being extremely patient and gentle are key -- if you even slightly bend a corner without damaging the wires, it becomes infinitely harder to get it in successfully. Most of the ribbons have small notches you can use to help you push them in and judge how far in they are.
Also if the wifi antenna wire gets loose when you're putting it back together, you'll have to undo everything to get it back into the right spot.
Chupi - Replica
My old 3DS is soft-bricked and nothing will work without opening it up. I want to know what I have to adjust before I open the device up.
afdflol82 - Replica
if you switch the mother board will all the memory on the 3ds be gone!?
Cristiano Miranda - Replica
Does anyone have a schematic download of the 3DS’s Motherboard for what each part of the board does?
Alkaris - Replica
I replaced a motherboard but now it won’t power on. The blue light comes on, it sits there for a few seconds, and then it turns off with the screen or anything coming on. Did I get a faulty replacement motherboard or did I do something wrong?
eric ofoe - Replica
What do I do about the adhesive on the SD slot? I don't want it to be too loose. Also I haven't done this yet but I plan to if I do this will I be able to still have all my data? I know it sounds like a stupid question but slight concern my 3DS works okay besides the fact that the charger port is broken
Excellent guide! I cannot feel the extremities of my fingers.
David Pires - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 512
Tutti i Tempi: 74,730
