Salta al contenuto principale
Nintendo 3DS Motherboard Assembly Replacement
Solo Prerequisita
Questa guida รจ destinata a essere usata solo come prerequisito per altre guide. Da sola รจ incompleta.
Cosa ti serve
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: passo 1, immagine 1 di 2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: passo 1, immagine 2 di 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: passo 2, immagine 1 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 2, immagine 2 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 2, immagine 3 di 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: passo 3, immagine 1 di 2 Nintendo 3DS Motherboard Assembly Replacement: passo 3, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: passo 4, immagine 1 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 4, immagine 2 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 4, immagine 3 di 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: passo 5, immagine 1 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 5, immagine 2 di 3 Nintendo 3DS Motherboard Assembly Replacement: passo 5, immagine 3 di 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  6. Nintendo 3DS Motherboard Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the motherboard assembly from the rest of the device.
Conclusione
David Hodson
Membro da: 04/13/10
150.503 Reputazione
127 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,578
