Introduzione
Remove your broken Nintendo 3DS lower case and replace it with a fresh one.
Strumenti
Parti
Nessuna parte specificata.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Altre 6 persone hanno completato questa guida.
