Salta al contenuto principale
Sostituzione batteria Nintendo 3DS
Cosa ti serve
  1. Sostituzione batteria Nintendo 3DS, Cover posteriore: passo 1, immagine 1 di 1
    • Svita le quattro viti a croce Phillips #00 lungo il bordo superiore della cover posteriore.
    • Le viti sono tenute in posizione da delle rondelle di bloccaggio, quindi non si libereranno dalla cover posteriore.
    • La sezione commenti è piena di persone sfortunate che ti diranno che le teste delle viti che incontrerai fino al passo 4 si spanano con incredibile facilità. Tenendolo premuto verso il basso con molta forza, ruota lentamente il cacciavite.
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - Replica
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - Replica
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - Replica
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - Replica
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - Replica
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - Replica
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - Replica
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - Replica
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - Replica
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - Replica
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - Replica
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - Replica
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - Replica
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
  2. Sostituzione batteria Nintendo 3DS: passo 2, immagine 1 di 2 Sostituzione batteria Nintendo 3DS: passo 2, immagine 2 di 2
    • Tieni il dispositivo in una mano e giralo.
    • Afferra il bordo superiore della cover posteriore con l'altra mano in modo che non ritorni al suo posto da sola.
    • Gira ancora il 3DS in modo che la cover posteriore sia rivolta verso di te.
    • Tira la cover verso l'alto per rimuoverla dal dispositivo.
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - Replica
  3. Sostituzione batteria Nintendo 3DS, Batteria: passo 3, immagine 1 di 3 Sostituzione batteria Nintendo 3DS, Batteria: passo 3, immagine 2 di 3 Sostituzione batteria Nintendo 3DS, Batteria: passo 3, immagine 3 di 3
    • Infila uno strumento di apertura in plastica nella fessura nella scocca inferiore sopra la batteria.
    • Fai leva con lo strumento di apertura in plastica per sollevare la batteria.
    • Afferra il bordo superiore della batteria e sollevalo dalla scocca inferiore.
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 45 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
David Hodson
Membro da: 04/13/10
150.493 Reputazione
127 Guide realizzate
7 Commenti
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Replica
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - Replica
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Replica
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Replica
I have replaced the battery and charger 3x the new batteries make it work but it will not charge
sarah peterson - Replica
Maybe the problem is the charging port
Nelson Berrios -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 77
Ultimi 7 Giorni: 481
Ultimi 30 Giorni: 2,207
Tutti i Tempi: 67,598
