Salta al contenuto principale
Nintendo 3DS Battery Replacement
Cosa ti serve
  1. Nintendo 3DS Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: passo 2, immagine 1 di 2 Nintendo 3DS Battery Replacement: passo 2, immagine 2 di 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: passo 3, immagine 1 di 3 Nintendo 3DS Battery Replacement, Battery: passo 3, immagine 2 di 3 Nintendo 3DS Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
Conclusione
Altre 45 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.493 Reputazione
127 Guide realizzate
7 Commenti
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Replica
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - Replica
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Replica
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 58
Ultimi 7 Giorni: 475
Ultimi 30 Giorni: 2,189
Tutti i Tempi: 67,654
