Introduzione
If your 3DS joystick is not responding, follow these steps to replace the joystick pad and get your device working again. Watch out for delicate ribbon cables in the device. There is a loose black washer in the joystick housing. Be sure not to lose it.
Strumenti
Ricambi
Nessuna parte specificata.
Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
Locate the joystick assembly near the top right corner of the motherboard.
Remove the two 8mm Phillips #00 screws from the back of the joystick.
Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
Altre 4 persone hanno completato questa guida.
