Panoramica Video
- 在取下后盖后,电池很容易更换。
- 背板由 Y 型螺丝固定。
- 耳机接口和充电接口都固定在主板上。
- 上部的显示屏被粘了起来,需要撬开但是很容易弄坏显示屏。
Considerazioni Finali
Punteggio Riparabilità
4
Riparabilità 4 su 10
(10 è il più facile da riparare)
Un ringraziamento speciale a questi traduttori:
en zh
75%
Patrick Zhang ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
18 Commenti
yet another yootoob tear-down...why? whats wrong with the others - some peeps cant get to yootoob during the day!
P Stephenson - Replica
Any idea how I can get my hands on a replacement back frame. I found a crack in the bottom right corner.
Nathaniel Canning - Replica
Why can’t i find a direct 2ds close upper screen replacement? Is it the same screen as the 3Ds Xl?
John - Replica
It’s not the same, the 2DS screen is in 2D and the 3DS has a 3D screen
Liam Judge -
Warning!
In the teardown video they show how to remove the ribbon cable, but beware! Two of these cable dont have the regular easy fit where you lift the flick to get it open and remove the cable. (Yes, they do this in the video and brake it.) Once they’re open” they wont close again.
The cable right above the cart slot is ond and the closes cabel to the joystick is the other. (The two with the back connectors)
BEWARE!
I have not tested this yet but it seems as it is a tight push fit to these ribbon cables.
If there is so, please let other people know so they dont do the same mistake as i by opening it and cannot close it again.
In worst case your New 2DS XL turn on!
Daniel - Replica
