Introduzione
This guide for the Nintendo 2DS will teach you how to access the trigger buttons to remove them for cleaning or replacement.
Parti
Nessuna parte specificata.
  1. Remove the two Phillips screws securing the upper rear panel.
    • Remove the two Phillips screws securing the upper rear panel.
    • The screws will not completely detach from the back panel.
  2. Hinge the upper rear panel upwards and outwards to remove it. Hinge the upper rear panel upwards and outwards to remove it.
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. Remove the ten Phillips screws attaching the rear panel.
    • Remove the ten Phillips screws attaching the rear panel.
    Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
    Little Mac - Replica
    I used a husky with changeable heads, you could probably find one on amazon
    Minecrafter Pig -
  6. The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  7. Carefully flip the back panel over to locate the attached ribbon cable.
    • Carefully flip the back panel over to locate the attached ribbon cable.
    • Remove the two Phillips screws attaching the ribbon cable to the rear panel.
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
    pivotanimationz - Replica
    pay attention: my 2ds dropped it's lens covers at this step
    Jos van Reenen - Replica
    The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
    Rick Parrish - Replica
  8. The trigger buttons have small springs attached to them, so be careful when removing the buttons from the device. Pull the trigger button away from the device to remove it.
    • The trigger buttons have small springs attached to them, so be careful when removing the buttons from the device.
    • Pull the trigger button away from the device to remove it.
    Thanks so much for these instructions. My nine year-old son just got Pokemon Sun and Moon on Friday evening. He had been talking about it non-stop for several months. On Saturday, he managed to bend the plastic lip on the base of his 2DS right trigger - the trigger button no longer worked. He was devastated, because we thought he had permanently broken his 2DS. We were afraid he would have to wait until Christmas (over a month away) before we could get him a new one.
    I found these instructions via Google, followed them to take apart his 2DS and remove the trigger button. I gently bent the plastic lip of the trigger back with needle nose pliers, reassembled the 2Ds, and the trigger worked perfectly! He now thinks I am the greatest dad in the world.
    bruce - Replica
    same situation here
    Minecrafter Pig -
Conclusione
Altre 16 persone hanno completato questa guida.
Fina Beauchamp
Membro da: 12/01/2015
2.261 Reputation
6 Guide realizzate
Cal Poly, Team 70-1, Forte Winter 2015 Membro di Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Membri
20 Guide realizzate
Nice job! My right button was jammed for at least two years. Now I can finally demolish my friends in Mariokart.
Minecrafter Pig - Replica
Past 24 Hours: 4
Past 7 Days: 65
Past 30 Days: 217
All Time: 14,920
