Salta al contenuto principale
Nintendo 2DS Battery Replacement
Cosa ti serve
  1. Nintendo 2DS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: passo 2, immagine 1 di 2 Nintendo 2DS Battery Replacement: passo 2, immagine 2 di 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: passo 3, immagine 1 di 3 Nintendo 2DS Battery Replacement: passo 3, immagine 2 di 3 Nintendo 2DS Battery Replacement: passo 3, immagine 3 di 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Conclusione
Altre 33 persone hanno completato questa guida.
Fina Beauchamp
Membro da: 01/12/15
3.024 Reputazione
6 Guide realizzate
Cal Poly, Team 70-1, Forte Winter 2015 Membro di Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Membri
35 Guide realizzate
4 Commenti
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Replica
This didnt help my problem
Artemy Matveev - Replica
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Replica
or maybe its just not working ludovic 🫡
Natalia Rabago -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 154
Ultimi 30 Giorni: 760
Tutti i Tempi: 40,778
