Salta al contenuto principale
Ninja Professional BL610 LED Replacement
Cosa ti serve
  1. Ninja Professional BL610 LED Replacement, LED: passo 1, immagine 1 di 1
    • Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver.
  2. Ninja Professional BL610 LED Replacement: passo 2, immagine 1 di 1
    • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
  3. Ninja Professional BL610 LED Replacement: passo 3, immagine 1 di 1
    • Remove five screws from circuit board using Phillips #2 screwdriver.
  4. Ninja Professional BL610 LED Replacement: passo 4, immagine 1 di 1
    • Once the screws are removed, lift the circuit board to access the back.
  5. Ninja Professional BL610 LED Replacement: passo 5, immagine 1 di 1
    • Locate the LED you wish to replace and note its position on the opposite side of the circuit board.
  6. Ninja Professional BL610 LED Replacement: passo 6, immagine 1 di 1
    • Desolder both of the LED leads and remove the LED light. Note the orientation of LED, this is important for replacing the LED. The Replacement LED needs to be soldered in the same orientation.
Conclusione
USF Tampa, Team S14-G3, Boczar Fall 2017 Membro di USF Tampa, Team S14-G3, Boczar Fall 2017
USFT-BOCZAR-F17S14G3
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 267
