Salta al contenuto principale
Ninja Professional BL610 Fan Replacement
Cosa ti serve
  1. Ninja Professional BL610 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver
  2. Ninja Professional BL610 Fan Replacement: passo 2, immagine 1 di 1
    • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
  3. Ninja Professional BL610 Fan Replacement: passo 3, immagine 1 di 1
    • Using a needle nose pliers, remove nut holding fan in-place. Be careful with fan blades and use a glove or a thick cloth to protect hands.
Conclusione
USF Tampa, Team S14-G3, Boczar Fall 2017 Membro di USF Tampa, Team S14-G3, Boczar Fall 2017
USFT-BOCZAR-F17S14G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 361
