Salta al contenuto principale
Ninja Master Prep QB900B button replacement
Cosa ti serve
  1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: passo 1, immagine 1 di 1
    • Place the blender to the side.
  2. Ninja Master Prep QB900B button replacement: passo 2, immagine 1 di 2 Ninja Master Prep QB900B button replacement: passo 2, immagine 2 di 2
    • Remove the two highlighted screws with a Phillips #2 Screw Driver
    • Gently pull off the top.
  3. Ninja Master Prep QB900B button replacement, Button: passo 3, immagine 1 di 1
    • Remove the highlighted screws.
  4. Ninja Master Prep QB900B button replacement: passo 4, immagine 1 di 1
    • Pull out the highlighted spring.
    • Now wash the button with soap and water, and follow the guide backwards to reassemble.
Conclusione
Altre 2 persone hanno completato questa guida.
Kamal Taha
Membro da: 08/27/15
679 Reputazione
5 Guide realizzate
USF Tampa, Team 1-3, Sullivan Fall 2015 Membro di USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Membri
5 Guide realizzate
2Commenti sulla guida
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Replica
turns out it was a security torx. how annoying.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,176
