Salta al contenuto principale
Ninja Kitchen System Pulse Fan Replacement
Cosa ti serve
  1. Ninja Kitchen System Pulse Fan Replacement, Base Disassembly: passo 1, immagine 1 di 1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Fan Replacement: passo 2, immagine 1 di 1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Fan Replacement, Fan: passo 3, immagine 1 di 1
    • Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
    • Place this screw on the magnetic mat.
  4. Ninja Kitchen System Pulse Fan Replacement: passo 4, immagine 1 di 2 Ninja Kitchen System Pulse Fan Replacement: passo 4, immagine 2 di 2
    • Remove the fan from the motor by gently pulling upwards.
    • Be careful as to not damage any wires when removing the fan.
    • Set the fan to the side.
Conclusione
Altre 3 persone hanno completato questa guida.
Cameron Just
Membro da: 01/20/16
391 Reputazione
3 Guide realizzate
USF Tampa, Team 15-1, Remmell Spring 2016 Membro di USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 886
