Salta al contenuto principale
Ninja Coffee Bar CF080 Brewer Head Replacement
Cosa ti serve
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: passo 1, immagine 1 di 1
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 2, immagine 1 di 1
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 3, immagine 1 di 3 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 3, immagine 2 di 3 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 3, immagine 3 di 3
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 4, immagine 1 di 1
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 5, immagine 1 di 3 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 5, immagine 2 di 3 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 5, immagine 3 di 3
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 6, immagine 1 di 1
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 7, immagine 1 di 2 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 7, immagine 2 di 2
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 8, immagine 1 di 1
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 9, immagine 1 di 1
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 10, immagine 1 di 2 Ninja Coffee Bar CF080 Brewer Head Replacement: passo 10, immagine 2 di 2
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: passo 11, immagine 1 di 1
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,009
