Salta al contenuto principale
Ninja Coffee Bar® Single-Serve System Power Cable Replacement
Cosa ti serve
  1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: passo 1, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: passo 1, immagine 2 di 2
    • Unscrew the eight 6mm #1 Phillips head screws off the bottom panel.
    • Lift lower panel up while passing the power cord through the opening.
  2. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: passo 2, immagine 1 di 1
    • Loosen two 6mm #1 Phillips head and remove clamp holding power cable.
  3. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: passo 3, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement: passo 3, immagine 2 di 2
    • Pull the power cable out exposing the two crimped ends.
    • Using a wire stripper/crimping tool, uncrimp wires.
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
Conclusione
CJ Berg
Membro da: 11/05/18
444 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 480
