Introduzione
If your frother unit is no longer providing you with delicious, foamy drinks then it may be time to replace the frother unit on your device. Use this guide to replace your frother and reclaim the ability to brew up specialty drinks with your Ninja Single Serve Coffee System.
Cosa ti serve
Remove four 6mm #1 Phillips head screws from under the basket area.
Remove the single 6mm #1 Phillips head screw from the side of the unit.
Un commento
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
