Salta al contenuto principale
Ninja Coffee Bar® Single-Serve System Frother Replacement
Cosa ti serve
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: passo 1, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: passo 1, immagine 2 di 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 2, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 2, immagine 2 di 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 3, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 3, immagine 2 di 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 4, immagine 1 di 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 4, immagine 2 di 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: passo 4, immagine 3 di 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Conclusione
CJ Berg
Membro da: 11/05/18
444 Reputazione
4 Guide realizzate
Un commento
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,533
