Salta al contenuto principale
Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement
Cosa ti serve
  1. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement, Valve: passo 1, immagine 1 di 1
    • Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Remove bottom cover
  2. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 2, immagine 1 di 1
    • Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Remover tube protection plate
  3. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 3, immagine 1 di 2 Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 3, immagine 2 di 2
    • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S13-G69, Cagle Fall 2017 Membro di USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 Membri
3 Guide realizzate
2 Commenti
Where can I get the replacement water valve?
Mark Peters - Replica
Anyone have a source for the valve?
ErrorCode67 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,907
