Introduzione
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
Parti
Nessuna parte richiesta.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Aggiungi Commento
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Zachary Phillips
Membro da: 08/04/2011
205 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,338
