Introduzione
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Parti
Nessuna parte richiesta.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Aggiungi Commento
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Aggiungi Commento
  • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
Aggiungi Commento
  • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
Aggiungi Commento
  • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
Aggiungi Commento
  • Remove the front case from the camera.
  • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
Aggiungi Commento
  • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
Aggiungi Commento
  • Desolder the wires and remove them from the communication board.
  • Note: If you are unfamiliar with soldering techniques, click here for a guide.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Zachary Phillips
Membro da: 08/04/2011
205 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,040
