Introduzione
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
  • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
  • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
Aggiungi Commento
Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
Aggiungi Commento
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Aggiungi Commento
  • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
Aggiungi Commento
  • Remove the battery compartment from the camera.
  • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Zachary Phillips
Membro da: 08/04/2011
205 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 88
Tutti i Tempi: 9,258
