Introduzione
Back case acts as a door to access change out film. It can be easily removed from the device and replaced if it becomes cracked or otherwise unusable.
  • In this guide we will refer to 'left' and 'right' as though the camera is facing away from you.
  • Pull up on the film rewind lever on the top left of the camera to release the back door.
  • Once the door is released, open it completely.
Aggiungi Commento
  • Locate the silver tab on the inside of the door hinge. Slide this down to free the hinge and remove it from the camera.
Aggiungi Commento
Conclusione
Zachary Phillips
Membro da: 08/04/2011
205 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,070
