Salta al contenuto principale
Nikon N2000 (F301) Battery Compartment Replacement
Cosa ti serve
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: passo 2, immagine 1 di 1
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: passo 3, immagine 1 di 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: passo 4, immagine 1 di 1
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: passo 5, immagine 1 di 1
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
12 Guide realizzate
Un commento
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 123
Tutti i Tempi: 17,277
