Salta al contenuto principale
Nikon D90 Remplacement de la carte SB/IF
Cosa ti serve
  1. Nikon D90 Remplacement de la carte SB/IF, Remove the bottom cover: passo 1, immagine 1 di 1
    • Remove the three screw in red
    • Remove the three long screw in orange
    • Remove the screw in yellow
    • Use a little of WD40 if the screw is blocked
  2. Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: passo 2, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: passo 2, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: passo 2, immagine 3 di 3
    • Remove the 4 screw in green
    • Remove the 2 screw in yellow
  3. Nikon D90 Remplacement de la carte SB/IF: passo 3, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF: passo 3, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF: passo 3, immagine 3 di 3
    • Slacken the grip side of the cover first
    • Remove the cover wholly.
    • Be carefull with the two flex cables
  4. Nikon D90 Remplacement de la carte SB/IF: passo 4, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF: passo 4, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF: passo 4, immagine 3 di 3
    • Disconnect the FPC of the back cover
    • Toggle up the black plate to free the flex cable
    • Remove the grip cover by rotating
  5. Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: passo 5, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: passo 5, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: passo 5, immagine 3 di 3
    • Toggle up the black plate and disconnect the flex cable
    • Toggle up the white plate and disconnect the flex cable
    • Push up the right slide of the connector to free it
  6. Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 2/3: passo 6, immagine 1 di 1
    • Push up the bottom of the connector to free it
  7. Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: passo 7, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: passo 7, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: passo 7, immagine 3 di 3
    • Remove the six screws to free the protection plate
    • Disconnect the white cables
    • Disconnect the microphone Cable
  8. Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: passo 8, immagine 1 di 3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: passo 8, immagine 2 di 3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: passo 8, immagine 3 di 3
    • Disconnect the speaker cable
    • Remove the two screws to free the PCB
    • Toggle th PCB from Left to Right
  9. Nikon D90 Remplacement de la carte SB/IF, Disconnect the cable on the bottom of the PCB: passo 9, immagine 1 di 1
    • Disconnect the black cables
  10. Nikon D90 Remplacement de la carte SB/IF, Free the IF/SB PCB: passo 10, immagine 1 di 2 Nikon D90 Remplacement de la carte SB/IF, Free the IF/SB PCB: passo 10, immagine 2 di 2
    • Push the IF/SB PCB
    • Unsolder the 3 Wires ( Red, Black, Orange )
Conclusione
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
JOLY
Membro da: 03/06/16
182 Reputazione
1 Guida realizzata
Nexurium - Bastien JOLY Membro di Nexurium - Bastien JOLY
Business
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,211
