Salta al contenuto principale
Nikon D90 Flash Bulb Replacement
Cosa ti serve
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, immagine 1 di 3 Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, immagine 2 di 3 Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, immagine 3 di 3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: passo 2, immagine 1 di 2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: passo 2, immagine 2 di 2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, immagine 1 di 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, immagine 2 di 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, immagine 3 di 3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: passo 4, immagine 1 di 2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: passo 4, immagine 2 di 2
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, immagine 1 di 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, immagine 2 di 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, immagine 3 di 3
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
Conclusione
Altre 8 persone hanno completato questa guida.
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Membri
6 Guide realizzate
2 Commenti
thanks for instruction…………really helpfull
hebi - Replica
Hi guys do you know where to get this bulb?please help
Martin Mitter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 20
Tutti i Tempi: 7,018
