Salta al contenuto principale
Nikon D80 Rear LCD Screen Replacement
Cosa ti serve
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: passo 1, immagine 1 di 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: passo 1, immagine 2 di 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: passo 1, immagine 3 di 3
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Nikon D80 Rear LCD Screen Replacement: passo 2, immagine 1 di 3 Nikon D80 Rear LCD Screen Replacement: passo 2, immagine 2 di 3 Nikon D80 Rear LCD Screen Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Rear LCD Screen Replacement: passo 3, immagine 1 di 2 Nikon D80 Rear LCD Screen Replacement: passo 3, immagine 2 di 2
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  4. Nikon D80 Rear LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon D80 Rear LCD Screen Replacement: passo 4, immagine 2 di 2
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  5. Nikon D80 Rear LCD Screen Replacement: passo 5, immagine 1 di 2 Nikon D80 Rear LCD Screen Replacement: passo 5, immagine 2 di 2
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
Conclusione
Sara Martin
Membro da: 10/09/17
586 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G1, Leahy Fall 2017 Membro di USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,749
