Introduzione
This guide will demonstrate the steps required to replace a problematic motherboard on your Nikon D610.
Cosa ti serve
After removal of the battery. Pull the battery compartment door away from the lens.
There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
Remove all the screws and the bottom face should pop off easily.
Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
There are screws hidden in three separate spots.
One is under the rubber doors on the left side of the camera. the next one at the eye hole.
The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
The rear side of the camera is where the motherboard is located. It is visible after you have taken off the rear face plate.
Remove the shield that protects it from static first.
This shield has six Philips #00 screws that are positioned around the edge of the shield.
After removal of the screws the shield will come free from the motherboard.
Altre 2 persone hanno completato questa guida.
