Salta al contenuto principale
Nikon D610 Battery Replacement
Cosa ti serve
  1. Nikon D610 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: passo 2, immagine 1 di 3 Nikon D610 Battery Replacement: passo 2, immagine 2 di 3 Nikon D610 Battery Replacement: passo 2, immagine 3 di 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: passo 3, immagine 1 di 2 Nikon D610 Battery Replacement: passo 3, immagine 2 di 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Conclusione
Daniel Eagan
Membro da: 02/10/16
606 Reputazione
5 Guide realizzate
USF Tampa, Team 4-4, Lacy Spring 2016 Membro di USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Membri
6 Guide realizzate
Un commento
This is my kind of fixing )
Loic - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,471
