Salta al contenuto principale
Nikon D5100 Memory Card Replacement
  1. Nikon D5100 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Nikon D5100 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Nikon D5100 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
  2. Nikon D5100 Memory Card Replacement: passo 2, immagine 1 di 1
    • Eject the memory card by pressing it into its slot until you hear a soft "click."
  3. Nikon D5100 Memory Card Replacement: passo 3, immagine 1 di 1
    • Using thumb and forefinger, gently remove the SD card from its slot.
Conclusione
Liz
Membro da: 04/25/14
1.311 Reputazione
5 Guide realizzate
Cal Poly, Team 10-54, Amido Spring 2014 Membro di Cal Poly, Team 10-54, Amido Spring 2014
CPSU-AMIDO-S14S10G54
4 Membri
5 Guide realizzate
Un commento
isn't this procedure in the user manual?
Happy Fixer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,343
